Case LA
Ap
10-27-2003 20:38:03
Hello, I just started a case LA that has been sitting for a number of years. When i started it after about 3 min. Oil started coming out of the starter housing... I have never seen this happen before any ideas as to what is wrong???
Thanks
Al
10-30-2003 08:20:34
 Re: Case LA in reply to Ap, 10-27-2003 20:38:03
The LA has an oil bath clutch but it does need to be drained each time you change the oil.... It probably has not been drained in ages. To Drain it there is a small plug on the bottom of the clutch housing. You do not need to refill it, it fills automatically when you run the engine, it is designed to fill from the engine but the oil can not get back to the engine, so that is that reason you need to drain it on occasion. be sure to check the oil level in the engine after you run it since the clutch filling back up will consume about a quart. It may take runing it for a couple of hours before it actually fills all the way up again.
Glen in TX
10-29-2003 23:08:42
I bet some of that thick black silicone that comes in a cheese can would seal it up.
Frank
10-28-2003 04:48:20
Assuming yours is like mine, indeed they have a wet clutch, but there is a rather thick, bevel edged rubber seal that goes on the neck of the starter where it extends into the bell housing. Case # 07299AB. Listed as NLA by my dealer.
case1979
10-27-2003 21:05:03
If you mean the oil is coming out where the starter bolts up. There is noting wrong with the LA it has an oil filled clutch housing. The oil from the engine cycles through the clutch housing.
