770 Case imfo.
Don V.
10-27-2003 16:52:41
Some of you out there must be experts on the 70 series. I'm looking at a nice 770 and need to know more about this series. Any info. will help. Thanks
John in New York
10-29-2003 09:07:08
 Re: 770 Case imfo. in reply to Don V. , 10-27-2003 16:52:41
I have a 770 with just over 1000 hours. Power shift and heated cab and a bucket. One problem. She will stall while under load if the fuel bowl screen is not changed or cleaned. Keep up with the plugs also. Thinking about selling mine sometime in the near future
Don V.
10-29-2003 16:40:38
 Re: Re: 770 Case imfo. in reply to John in New York, 10-29-2003 09:07:08
Thanks for the info. John: If you decide to get rid of it, give me a shout.
brian in ky
10-29-2003 04:23:14
They are between 55 and 65 hp. Depends on the RPM setting. They are ok but just a little big for the hp. Mine is a powershift and I prefer the 8-spd, less to go wrong. I pull a 15ft batwing, 3-16 plows, 430 JD roll baler and other implaments with mine. The 870 was a far better tractor then the 770.
Don V.
10-29-2003 16:47:17
 Re: Re: 770 Case imfo. in reply to brian in ky, 10-29-2003 04:23:14
I can see where the 8-speed would have it's advantages in a lot of applications. Also sounds like pretty good hp. May be what I need. Just never been around the 770 and needed the in-put from some of you. Thanks!!
David
10-27-2003 17:39:55
I think they just built them 2 years i had one no trouble. mine was a power shift i liked it for a small brush hog or 3/point sprayer no complaints.
Don V.
10-28-2003 15:57:36
 Re: Re: 770 Case imfo. in reply to David , 10-27-2003 17:39:55
Thanks for the reply David> Do you know what horse power.
