LA manifold question
zac
10-27-2003 06:13:02
I just bought a 48 LA, the manifold is cracked and I have a good one in the shop. But the cracked one is different, its built square where the carb bolts onto it, as where the good one is a more pipe like going into the carb. I know the carb will bolt up but will it run right? I assume the cracked one is like an oliver 80 and used heat to warm the intake pipe from the carb. Any help is appreciated, thanks in advance.
Tom Railsback
10-27-2003 06:20:11
 Re: LA manifold question in reply to zac, 10-27-2003 06:13:02
YOu are correct in assuming thzt it's an all fuel manifold; it will work just as well as a gasolinf manifold. However, if you were closer to me (Central Montana) I would gladly trade with you so I could have the correct manifold for my L.
