830 seized, everything went wrong
GeoMo
10-27-2003 06:08:29
Started fine let idle until warmed up.
Shut down and started 15-20 minutes later and took a mile down road.
Shut down 5 minutes and then drove 1/8 mile-throttled down to turn into field and it shut down like fuel was shut off. No noise. Cannot turn over with starter or by pulling. Have had no problem with clutch but dosn't come close to sliding wheels even on gravel.
it has not how the power lately that it should, I blamed it on the fuel from last winter, 70% # 2 and 30% #1
Klyde
10-28-2003 11:18:38
 Re: 830 seized, everything went wrong in reply to GeoMo, 10-27-2003 06:08:29
Having a hard time figuring this out---did it stop quick, or did the engine roll to a stop? Did you try an turn the engine backwards?? Whats the bit about the clutch? When you tow it it slides the tires? When you tow it the clutch slips and the engine remains seized? Let us know. I'm interested in what you find.
GeoMo
10-29-2003 05:10:02
 Re: Re: 830 seized, everything went wrong in reply to Klyde, 10-28-2003 11:18:38
When I cut the throttle back to 1/2 it was if I had shut it completly off or like a pulling dead.
I have not tried turning backwards.
The clutch never slipped but now it will not slide the wheels when towing.
Another odd thing the hyd oil is discolored (grey)I have seen with air and water mixed but this looks different. Motor oil looks ok.
R. Marg
10-27-2003 07:48:33
sounds like you have fuel in the oil that will seize one up
GeoMo
10-27-2003 11:26:57
 Re: Re: 830 seized, everything went wrong in reply to R. Marg, 10-27-2003 07:48:33
Cannot detect any fuel in the oil.
If so what can be done?
R. Marg
10-27-2003 13:26:53
 Re: Re: Re: 830 seized, everything went wrong in reply to GeoMo, 10-27-2003 11:26:57
on my AC 190XT I had to replace the drive seals in the injector pump I also had to put turpentine in the cylinders to get it to brake loose again hope this helps
GeoMo
10-27-2003 15:03:24
 Re: Re: Re: Re: 830 seized, everything went wrong in reply to R. Marg, 10-27-2003 13:26:53
Thanks a lot.
How did you get turpentine in the cylinders?
R. Marg
10-27-2003 15:09:59
 Re: Re: Re: Re: Re: 830 seized, everything went wr in reply to GeoMo, 10-27-2003 15:03:24
you have to pull the injectors and if its like the 190 was its no fun
GeoMo
10-28-2003 05:17:58
 Re: Re: Re: Re: Re: Re: 830 seized, everything wen in reply to R. Marg, 10-27-2003 15:09:59
Thanks Again
It will worth the effort if i can save the old girl without a major expence.
R. Marg
10-28-2003 06:17:25
 Re: Re: Re: Re: Re: Re: Re: 830 seized, everything in reply to GeoMo, 10-28-2003 05:17:58
it worked on my 190 can't say it will work for you but I think its worth a try hope you have luck with it
