Need help with magneto
John
10-25-2003 22:52:11
I have a Case magneto for my 1940 mod D. The condensor is shot and I need a new one. The only number I can find on the condensor is 20. The condensor is flat approx 1" x 1 1/2" by 1/4" with one wire out the top. The magneto is a Case and the only number I can find on it is probably a cast number of 64985. Where can I find a condensor like this. People I talk to say they never saw a flat condensor before. Will a regular car condensor work? If so does it make a difference if it is a 6 or 12 volt. Can someone tell me where I can find a new one? Thanks
Glen in TX
10-27-2003 10:42:57
 Re: Need help with magneto in reply to John, 10-25-2003 22:52:11
John, If you have the old base mt. Case mag I have some good NOS condensers with the 20 on them. If you have the flange mt. with the rectangular cond. can exchange it or supply a capacitor to put in it. For the .20 mfd round condenser on the flange mt. use a aftermarket condenser I can supply. Set the points at .015-.020 and the dot one gear does line up with the red beveled teeth on other gear.
John
10-27-2003 18:53:27
 Re: Re: Need help with magneto in reply to Glen in TX, 10-27-2003 10:42:57
Glen, I have the old base mount Case magneto. I cleaned it up and everything looks good in it. I know I will need points later on. I would like to get a couple condensers with the 20 on them so I have an extra. email me at [email protected] and let me know how much they are and where I can send a check to. Do you want the old condenser? Thanks,
John
Mike Schotte
10-28-2003 01:21:25
 Re: Re: Re: Need help with magneto in reply to John, 10-27-2003 18:53:27
Whoops.... I didn't clue in that your tractor was early enough to have a base mount mag.
Those condenser part #'s I gave you were for a flange mount magneto.
Luckily Glen got you straightened out- he's the magneto man!
-Schotte
Mike Schotte
10-26-2003 01:03:21
John,
Neither the rectangular Case condenser (part #104 JMA-30) or the later cylindrical condenser (part #6-41-A) are available anymore, unless you find somebody with N.O.S. parts.
According to the parts lists I have here, the rectangular condenser was a 30 microfarad unit and the round condenser was a 20 mfd unit.
Here's a link to a fellow who told me he could sell me modern condensers that were of the right size to be retrofit in place of the old:
Good luck! -Schotte
John
10-26-2003 10:23:38
 Re: Re: Need help with magneto in reply to Mike Schotte, 10-26-2003 01:03:21
Thanks for your help on this Mike. Do you also know what the point setting is supposed to be for this magneto? When it is timed I suspect the dot on the smaller gear is supposed to line up with the red mark on the larger gear. Am I right in assuming that will be timed on the #1 spark plug wire? I really appreciate your assistance.
John
