Little cranks on the dash of a 47 DC 4
Glen
10-25-2003 19:39:27
My DC 4 has a little crank on the one side of the dash and a place for another one on the other side. What were these for?
The tractor has two gas tanks.... I was told the small one was for gas and the larger tank was for "distalate"..... Is this true??? What is distalate?
Thanks...
Glen
Don Rudolph
10-25-2003 19:54:05
 Re: Little cranks on the dash of a 47 DC 4 in reply to Glen, 10-25-2003 19:39:27
Glen,
The little crank is to close what are called radiator shutters that restrict the airflow through the radiator so the tractor runs hotter so the distillate or "low cost fuel" would ignite and run well. Most old timers have told me it was somewhere between kerosene and diesel fuel and it was a cheap by product of refining. The large fuel compartment was for low cost fuel and the small one was for regular gasoline. The procedure was to start the engine on gas, let it run and warm up well and the switch it over to low cost fuel. When you were done for the day you were supposed to switch it back to gas to make starting easier the next time you needed the tractor.
Glen
10-25-2003 20:06:29
 Re: Re: Little cranks on the dash of a 47 DC 4 in reply to Don Rudolph, 10-25-2003 19:54:05
Thanks....
There is a assembly on the other side of the dash for another crank (mine doesn't have a crank in it) what was that used for??
Glen
dctom
10-25-2003 20:31:48
 Re: Re: Re: Little cranks on the dash of a 47 DC 4 in reply to Glen, 10-25-2003 20:06:29
that one was used to close and open the baffel in the hot manafold to make the intake from carb to head hot for keroseine or dislent
