vac 14 steering
clyde
10-25-2003 18:03:36
I got the long tie rod apart by cutting a very thin groove along the tie rod tube with a cut off wheel in my hand grinder. Only way I could get it apart, heat,pressing,and cussin' wouldn't work. I only cut the groove through the tube, not into the tie rod. With a little wire welding and a file it will look good as new. I also used 2 tubes of anti-seize when I put it back together. Hope this can help someone else.
