CASE DC-4 ? MISC
CHARGER
10-24-2003 18:31:52
I JUST AQUIRED AN OLD CASE TRACTOR TO WORK ON WITH MY 4-H GROUP.WE ARE TOLD IT IS A DC-4 THE SERIAL NUMBER IS 5516361 D THE FRONT AXLE IS UNDER THE BODY, THE WHEELS DO NOT STICK OUT THE FRONT.IF THIS IS A DC-4 WOULD THE SN# NOT HAVE A DC AFTER THE NUMBER??. ALSO WHAT SIZE/PROFILE OF TIRE WAS ORIGINALLY ON THE FRONT THE RIM IS A SOLID 16INCH CASE WHEEL WAS IT A 3RIB? AND IF SO WHAT WAS HEIGHT 7.50? 6.00?. ANY HELP GETTING US STARTED WOULD BE GREATLY APPRECIATED. THANKS, PETE....
dctom
10-25-2003 08:16:36
 Re: CASE DC-4 ? MISC in reply to CHARGER, 10-24-2003 18:31:52
also dose it have a flat radiator grill?
CHARGER
10-25-2003 15:48:59
 Re: Re: CASE DC-4 ? MISC in reply to dctom, 10-25-2003 08:16:36
THE FRONT OF THE NOSE IS ROUNDED
dctom
10-25-2003 08:15:22
Charger: just what dose this tractor look like, is it real narrow like only 4 feet wide, dose it have 24 inch tires on the rear and 6.00x16 tires on front?
DINT 5616361 was built may 9 1952 and shipped to r w blair equipment co in conn,may 18 1952 the ink is all blurred and cant read name of town let me know if this is your tractor, di narrow tread's are rather rare as only 445 were built will make a very good project for your 4-h club dctom
CHARGER
10-25-2003 16:03:34
 Re: Re: CASE DC-4 ? MISC in reply to dctom, 10-25-2003 08:15:22
THE FRONT END OUTSIDE TO OUTSIDE OF THE TIRES MEASURES APP. 58IN. THE REAR TIRES ARE 38IN. ON 6 SPOKE WHEELS THEY ARE ADJUSTABLE IN AND OUT ON A ROUND STOCK AXLE. THE FRONTS ARE 9.50X16IN. ON SOLID CASE 3-STUD WHEELS. i AM STILL CONFUSED ABOUT THE DC-4 ISSUE ALL THE PICTURES OF DC-4 IN THE TRACT. PHOTO SECTION OF THIS (AWESOME) WEBSITE APPEAR TO LOOK EXACTLY LIKE OURS THE DC WITH THE FRONT WHEELS DO NOT. ARE WE MISSING SOMETHING?? IS OURS JUST A D?? THIS TRACTOR AS FAR AS I KNOW WAS PURCHASED IN MANITOBA CANADA??
WE REALLY APPRECIATE THE HELP WE ARE RECIEVING... REGARDS, PETE..
dctom
10-25-2003 17:32:25
 Re: Re: Re: CASE DC-4 ? MISC in reply to CHARGER, 10-25-2003 16:03:34
charger" i will check the number again and yes check the number on the block it may be diferent, what you discribe is sertinaly a DC-4 but the number is a DINT but i will check again tomorrow to make sure dctom
CHARGER
10-26-2003 06:34:25
 Re: Re: Re: Re: CASE DC-4 ? MISC in reply to dctom, 10-25-2003 17:32:25
HEY GUYS WE CAN SEND PICTURES IF NEEDED JUST ASK! REGARDS,ETHELBERT 4-H
John H-WI
10-25-2003 16:37:37
From what you describe it should be a DC-4 with adjustable rear wheels and the round front. The serial is also stamped on the block on left side towards the rear where it connects to the transmission housing. See if it says anymore than "D" there.
CHARGER
10-26-2003 06:30:32
 Re: Re: Re: Re: CASE DC-4 ? MISC in reply to John H-WI, 10-25-2003 16:37:37
NO LUCK WE CHECKED UNDER THE OIL RESEVOIR ABOVE WHERE THE OIL PAN BOLTS ON AND BACK TO THE TRANNY AND THERE APPEARS TO BE NO #S ???? IS THIS SOME KIND OF WIERD CANADIAN THING? WAS THERE A CASE PLANT IN CANADA? ANY OTHER SPOTS FOR NUMBERS. THIS PROJECT IS BECOMING MORE INTERESTING BY THE DAY. THANKS GUYS!!!!
dctom
10-24-2003 19:39:17
Pete; i will look up the build card on that tractor tomorrow and give you the date built and where shipped and tire sizes,
you must remember that all D series tractors were the same except for axles and wheels, diffeerent wheels and axles made a diffeerent tractor dctom
John H-WI
10-24-2003 18:50:26
If you only have a "D" after the serial number it is a "D" rather than a DC-4. The "D" has fixed axle on the front and rear whereas the DC-4 has an adjustable rear axle. Its a 1951 model according to the serial number. Most of the newer tractors of that vintage had the 3 rib front tires. 7.50 X 16.
