trying some different oil
todd hamilton
10-24-2003 17:36:30
I think I will start a huge debate. Changed the oil in the SC this afternoon - I service it in the fall as we use it to plow snow. I have been running straight 30W but it can be plenty stiff when the outside temp is under 10 degrees. Tractor always starts - I keep it shedded. This year I am trying Pennzoil Long Life 15W40. Maybe it will start easier when it is very cold and burn less oil when warmed up (it needs rings.) No lectures allowed about non-detergeant oil as I have already knocked the sludge loose over the past four years. I find less in the pan every time I change the oil.
Jim Handke
10-24-2003 18:01:43
 Re: trying some different oil in reply to todd hamilton, 10-24-2003 17:36:30
It's what we use on our SC with a front mounted buzz saw.
Les...fortunate
10-24-2003 19:35:06
 Re: Re: trying some different oil in reply to Jim Handke, 10-24-2003 18:01:43
Wish I had one of them saws for either the SC or the VAC. Got a big pile of slabs that would be perfectly suited to that equipment.
I'm thinking of switching to 20 weight very soon. Maybe the 15W40 ain't a bad ideer though. Dare I try it this winter?
dctom
10-24-2003 17:52:57
sounds good, i use straight 40 racin oil and 12 volt battery old dc start every time dctom
todd hamilton
10-24-2003 18:23:25
 Re: Re: trying some different oil in reply to dctom, 10-24-2003 17:52:57
Since we are both in Indiana you remember last winter was pretty drastic. A couple of those mornings running straight 30W I would watch the old oil pressure go to 10, then 15, in a little bit up to 20 and then about 24, which is normal for my old tractor. One time I idled down and the pressure went to 5 - it only needed 3 quarts. I wasn't checking it much in the cold weather but I put a pitcock in the top hole of the pan today. I already like it!
dctom
10-24-2003 19:43:16
 Re: Re: Re: trying some different oil in reply to todd hamilton, 10-24-2003 18:23:25
yes it was cold but a good pump and good bearings and i get 35 # quick and that racing oil is a little sticky stays put even when hot dctom
