case 580ck shuttle transmission
John Suchocki
10-24-2003 16:16:16
Has anyone ever had this problem? I just rebuilt my failing 580 ck with the torque converter and shuttle transmission. All torque converter and torque tube diameters rebuilt and or sleaved back to spec's. Put it together and the damm thing has 190 psi on the clutch gauge but won't move. When I shift from foward to reverse it just bumps and then it feel like the brakes are on. If I carefully dump the clutch, just feathering it, with it in gear it will move, but the clutch pressure goes down to about 50 psi.Too far on the clutch pedal and it will dump to 0 psi not enough and it won't move at all. Very fine line and its not in the adjustments there right on spec 3.10 inches to the first bolt to the center of the spool bearing shaft. Could my converter pressure be to high? I didn't make any adjustment on the system caused it worked somwhat when I took it apart. I did every very carefully and with the manuals all new parts internally. Maybe tighting up the system brought pressure back that was adjusted for before. Anyone ever had this problem? HELP!!!
Steve Schmittgens
10-29-2003 13:55:48
 Re: case 580ck shuttle transmission in reply to John Suchocki, 10-24-2003 16:16:16
John, Call me @ my shop (314)966-6692, it's quite possible that if you have the Rockford Style clutch pack that you might be engaging two clutches at once. I need to talk to you to get a better idea of your problem.
Steve
