Case model 311 need manifold
David McDaniel
10-24-2003 07:58:56
Trying to find manifold and gasket for Case 1956 model 311, sn. 6052147, engine no 11-00891 gas round front, lights in front of steering wheel.
Would anyone be able to find this.
Terrance
10-25-2003 08:56:57
 Re: Case model 311 need manifold in reply to David McDaniel, 10-24-2003 07:58:56
I have one,email me off list.
Terrance
C. Amick
10-24-2003 13:57:33
Here are some possible sources: Don L. 507-433-0073, MFT/USA 915-877-3343, and Rosewood Machine 937-362-3871. If it is not cracked badly or the hole is not too large, it can probably be welded either with a torch and some brass or with electric weld using a cast iron rod.
TerryH
10-24-2003 10:53:29
Someone will respond shortly with good info for you on your request. I see your request freqently What is wrong with yours and why do you need a new one?
Terry
David McDaniel
10-24-2003 11:17:49
 Re: Re: Case model 311 need manifold in reply to TerryH, 10-24-2003 10:53:29
Terry the one on this tractor has a hole in it. Have not found anyone to try and weld this hole.
My brother owns this tractor and trying to help him out. Thanks very much for the reply.
David
george md
10-24-2003 12:58:17
 Re: Re: Re: Case model 311 need manifold in reply to David McDaniel, 10-24-2003 11:17:49
David ,
You get it here and I'll weld it .
george
