Amp meter wiring
Scott Hawley
09-29-2006 16:24:42
I have a case 580 CK that never had a amp meter originally. I have bought one from the TS store and was wondering if anyone could help with the proper wiring sequence for it.
Thanks for any help,
Scott
Bob
09-30-2006 01:09:27
 Re: Amp meter wiring in reply to Scott Hawley, 09-29-2006 16:24:42
Connecting an ammeter, in general...
Connect a lead from the battery... typically from the starter solenoid terminal, where the (+) battery cable is connected, to one side of the ammeter.
Connect the output of the charging system, and ALL electrical loads to the other side.
If the ammeter reads backwards, swap the connections from one terminal to the other.
Jim B.
10-01-2006 18:37:19
 Re: Amp meter wiring in reply to Bob, 09-30-2006 01:09:27
Not "ALL" ... don't run the starter current thru the amp-meter, it cannot carry the load. Make sure the connections are made on the battery side of the starter solenoid.
