low power on a vac gas
ken bartos
10-21-2003 20:07:27
the vac gas case that i have turns over twice and starts but i have no power. it is like you are starting off in a high gear it just bougs down and you have no throttle it idles fine and you have high rpm when the tractor is not moveing . do Ihave a governor or a distributor problem thanks you
todd hamilton
10-22-2003 07:38:43
 Re: low power on a vac gas in reply to ken bartos, 10-21-2003 20:07:27
My SC will do that if the lean/rich control on the carb is not set just right. My aunt has a driveway that is long and uphill. I would adjust the mix and run it up the hill. When it would pull up the hill in 4th gear without bogging down I figured that was about right. Make sure that the carb bowel under the float is clean and unobstructed. If power improves when you pull out the choke a little then your mixture is too lean. If there is black smoke and the engine coughs and bogs then it is too rich. Weather affects mine so I set it a little lean and adjust it with the choke when using the tractor. The adjustment is sensitive.
John
10-21-2003 22:22:55
that sounds like what happens to my VAC when i run out of gas. you should clean the carburetor and fuel filter bowl under the gas tank
