Who bores wet sleeve blocks?
PLEASE HELP
10-21-2003 18:33:22
I have exhausted all avenues trying to find a local machine shop that will bore my CASE 284 block to accept bigger sleeves. They tell me it's hard to bore a wet sleeve engine. Who is the best machine shop to do this that is closest to Arkansas? In fact, I'd like to know even if they're not close to Arkansas. I need you help. Thanks in advance.
george md
10-21-2003 19:55:55
 Re: Who bores wet sleeve blocks? in reply to PLEASE HELP, 10-21-2003 18:33:22
Boring a wet sleeve block is no more difficult than boring an automotive block, though it does require a few more tools. Need a dial indicator to read bar travel for cutting counterbore , a depth mic to read counterbore depth accurately , a sleeve cut off tool for bar to cut counterbore and an angle tool to cut oring entry chamfer in lower bore. A little imagination to tie the bar in place would help , usually use a plate or bar across the bottom of the adjacent cylinder . It might even be easier with a cyl boring machine than with a portable cyl bar. I bore quite a few ford tractor blocks for flanged repair sleeves. JD 4020 blocks are known for sinking between the sleeves , for those we deck the block then recut the counter bores. also AC 301 block, the hopped up one that used to be the 2900 engine became the 649I in the 70-- tractor, perferates the liners and erodes the lower bore where the orings go .I bored the lower bore and made repair sleeves to install in the bore , pressed in , bored in place, and cut entry chamfer for orings . Have cont'l blocks that were cracked between the sleeves , bolted the block together , ground and welded the cracks , recut the counterbore and upper pilot bore with cyl bar,then decked the block .
george
PLEASE HELP
10-22-2003 03:29:19
 Re: Re: Who bores wet sleeve blocks? in reply to george md, 10-21-2003 19:55:55
Sounds like you have experience. Where are you located?
george md
10-22-2003 09:34:33
 Re: Re: Re: Who bores wet sleeve blocks? in reply to PLEASE HELP, 10-22-2003 03:29:19
Md , a little far for you to travel .
george
