David Brown 1200 help! Elmer?
Frank in Napa
05-19-1999 09:56:28
I have a 1968 DB1200 with a 4 cyl diesel. I just broke the crank and ruined most everything to do with the valvetrain. I would like to know any sources for parts and info on this tractor. I would love to find one that's being parted out on the west coast. Question for Elmer (or anyone else). What other models will have an engine that would be a direct swap? Are all the DB 4 cyl diesels the same for certain years? What are the odds that parts on mine would be the same as parts on a 1972 model (see Jim's post further down the list). I need to get this thing up and running soon but I'm not made of money.
Elmer
05-19-1999 17:38:48
 Re: David Brown 1200 help! Elmer? in reply to Frank in Napa, 05-19-1999 09:56:28
Also found some engines that i've had apart, the main caps have hammered on the block. The main bolts were a hair to long and inapropriate torque was applied to the caps. If the crank journal radius is ground at the wrong degree your guaranteed breakage. The right man is needed for the job
Elmer
05-19-1999 17:31:10
Their are Aftermarket parts available. I'll email you some info.
Richard M. Conklin
07-19-1999 11:24:35
 Re: Re: David Brown 1200 help! Elmer? in reply to Elmer, 05-19-1999 17:31:10
I am looking for clutch parts for my 1200 David Brown. The springs in old clutch are colored green.
