Reassembling Case electrical
krum
10-21-2003 10:55:29
It's time to get the '51 Case SC running. The coil was removed before I received the tractor. The local Farm and Fleet didnot have a new 6 volt coil. I have some old coils off from cars and trucks that I'm unsure if they are 6 volt or 12 volt off. How can I tell and if they are 6 volt will they work on the tractor. Also is there a simple way of testing a coil to see if it is good. The tractor had it's magneto replaced with a distributor. When pulling out the battery I noticed that the battery was hooked up as a negative ground. Would this be correct since the tractor was converted to a distributor? If tractor is run as a negative ground which way do you hook up the wires on the coil? Thanks in advance for any help.
Baggsy-Wy
10-21-2003 15:28:24
 Re: Reassembling Case electrical in reply to krum, 10-21-2003 10:55:29
If it's running off of an alternator, I believe it has to be negative ground. And SC's were negative ground with the magneto anyway...
R. Marg
10-21-2003 14:24:19
if its neg. ground the neg. side of the coil goes to the disturbor and as far as the coil a car coil works well to test it hook up a wire on both sides - and+ hook one to a battery and touch the other on and off to the other pole of the battery and heres the bad part you put a coil wire on it and hold it at the same time you are on and off touching the one wire to the battery if you jump it works or you can hold the coil wire to the side of the coil and watch for a spark
