Weight of 530ck with 32 loader and hoe??
Tom
10-21-2003 06:17:13
Can anyone tell me the weight of an older 530ck with a model 32 loader and backhoe? I want to know the weight before it is loaded onto a trailer. Thanks in advance for any help.
Max
10-21-2003 20:29:19
 Re: Weight of 530ck with 32 loader and hoe?? in reply to Tom, 10-21-2003 06:17:13
Figure the higher 10,000 pounds for a lot of these units have wheel weights and/or fluid in the tires. You can use a 1 ton to haul but be sure the trailer brakes are operational before you take off with all the nuts out there on the road today. Also lay the the hoe down as far as it will go to keep your center of gravity low as possible on the trailer. I never trusted much in the figures given out on these older units for when I was working at that Case company store back east the weight was usually the higher number when you went over the scales. The only weight number that culd be trusted was the weight spec for the Drott excavators.
Chris Brown
10-21-2003 09:36:58
Sorry I can't tell you the exact weight. I haul mine behind a 1 ton pickup on a tandem axle gooesneck 20' with the hoe down on the deck. It is not too heavy for the truck and trailer. I will guess around 7500# but definately not over the 10,000# George said
George S. in the real NY
10-21-2003 06:27:10
Tom, Figure on 10,000# for that whole setup. More than you want behind a pickup unless you are only going a few miles. I suggest that it is money well spent to hire an equipment mover to handle big stuff, anything screws up along the road, he has to talk with the bears. Often, farm machinery dealers will be able to do it. Remember also to watch overall height.
