NEED 52 DC AUX TOP LINK MOUNTING BRACKET
Errol CO
10-20-2003 06:52:31
I need the alternate top link mounting bracket or as the book calls it the "Alternate Depth Control Adjusting Screw Mounting Bracket" that is mounted on top of the hudraulic sump housing top cover. If some one has one or knows someone who might have one or where I might find one that might be sitting on a parts tractor somewhere I would be greatly appreciated! This is on a 1952 Case DC with the Eagle Hitch. I do not have the PTO guard that has one on it or the aux one I am looking for, it makes it rather hard to use the 3-point option so before I have one made I would like to try to find a original. Eventually I would like to find both brackets, the guard, and (this is really wishing!)the original Case Eagle Hitch Top Link. I would even consider one that had been made to accomadate a single hole aftermarket top link like the one I have on my JD "A" tractor. Thanks for any help! Errol
Bruce Nelson
10-20-2003 09:53:24
 Re: NEED 52 DC AUX TOP LINK MOUNTING BRACKET in reply to Errol CO, 10-20-2003 06:52:31
If this is the bracket that bolts on the PTO clutch cover and has two holes in it that bolt to the tractor, I have one. Let me know if I should hunt it up. Bruce
Errol CO
10-25-2003 05:02:36
 Re: Re: NEED 52 DC AUX TOP LINK MOUNTING BRACKET in reply to Bruce Nelson, 10-20-2003 09:53:24
Bruce! Did you have any luck finding the bracket???
Errol CO
10-20-2003 15:28:05
Hi Bruce! It sounds like what I am looking for, I am going by pictures but it is the bracket that is normally mounted on the left side on the top pto clutch cover held down with the left 2 pto clutch cover bolts with the big round part for the top link to hook to :-) If you can find it that will be great! Let me know when you do!
george md
10-20-2003 18:41:04
 Re: Re: Re: NEED 52 DC AUX TOP LINK MOUNTING BRACK in reply to Errol CO, 10-20-2003 15:28:05
Errol,
That upper link mounting bracket is used for 3 pt pto equipment , it is too high to use for most 3 pt equipment. using that bracket most 3pt eqip won't lift high enough ( tail wheel of plow will drag ground ) . I tried it near 50 years ago , didn't work then and I doubt it will work now.
george
