another seal question
Joel Shelton
10-19-2003 20:27:55
I am still trying to figure out my brake/gear seal dilema. How do you tell if you have the seal in backwards? does the cone shape go facing in or facing out? Like this ( representing in or ) representing out This would represent the lip/rubber of the seal. It has numbers on once side maybe they go in or out? It was leaking before I took the seals out and there was no obivious damage and I forgot to write down how they were in. Maybe they were put in wrong by the last owner and that is why it was leaking.
thanks
Joel
Russ
10-20-2003 16:38:00
 Re: another seal question in reply to Joel Shelton, 10-19-2003 20:27:55
Seal inn; I agree with Frank, Roger and F.I.T. their combined good advice is something you should
follow in your repair activities.
Keep the lubricant internal and the crud external.
Roger
10-20-2003 09:35:40
Joel, if you look on the inside of the seal, you should see a small spring around the seal lip, that is the side you want toward the oil you're trying to keep inside the housing.
Frank
10-19-2003 22:24:59
You need to have the seal lip ( if the oil is on this side of the seal to keep the oil on that side of the seal. If you were trying to keep contamination like water from getting into the innards then the seal would be ). Some applications use 2 seals, the outer one ) to keep the crap out and ( to keep the oil in.
F-I-T
10-19-2003 20:49:55
Joel:
I always describe the seal installation as the closed side faces out, and the open side towards what you don't want to pass. That puts the sharp edge of the seal pointing inwards to resist the flow of fluid outward.
Does that help at all?
Frank
