Case Fuel Inj. Pump
JohnMc
10-19-2003 17:58:20
I've been trying to get my Case 580CK running again after being idle for over a year now. While trying to bleed the injector lines to prime it up, I found that #2 injector has no fuel coming to it. All the others have moderate flow (I've seen better). I decided to take off the injector line going straight to the fuel injector. Still no fuel from there after cranking. I decided to pull the injector out (a bit more involved) since I figured the pump is bad somehow/someway. Short of getting a new one, does anyone know of what to check now? The only thing I noticed was that the o-rings on the shaft going into the injector pump were in pretty bad shape. Any other suggestions for getting good fuel flow to all cylindars?
george md
10-19-2003 23:10:30
 Re: Case Fuel Inj. Pump in reply to JohnMc, 10-19-2003 17:58:20
John,
sounds like one of three problems. Either
you didn't get all the air bled out or inside the
pump the arm broke off the metering valve or #3
the pump pistons are stuck (gummed) .
and the obvious , the shut off is not pushed
forward far enough.
george
