david brown 885 part number for seals
don
10-19-2003 11:08:07
I have a DB 885G and need part number for the seals where the axle goes into the gearbox housing.The local dealer had no part numbers for it. I rebuilt the final drive assembly but cannot find part number for the axle seals. I appreciate any help on this.
Thanks
Elmer
10-19-2003 11:22:36
 Re: david brown 885 part number for seals in reply to don, 10-19-2003 11:08:07
The part number for the seal in axle/differential housing is K13353, there are two on each side. The seal behind the drum is K623409. Would not hurt to do all of them while it is apart. REMEMBER!!!! tie down the differential lock pedal in the engaged position. If you don't you will hate yourself.
