Seals and Case SC brakes----Help!
Joel Shelton
10-18-2003 17:43:38
Ok,last month I found that I had no good brakes on my 1950 case sc. So I took off the brake housing and found that the seals were bad behind both the brakes. I think these were the gear seals that were between the brakes and the gears in the transmission. This was allowing the transmission oil/grease to leak onto the brakes and the brakes would not hold due to having grease on them. So I went and bought new seals and my father replaced them. We then cleaned and adjusted the brakes per case directions and before we put new 80/140 gear oil the brakes were working very well. No issues at all. Now I get a call today from my father telling me that after we filled the transmission back up with 9 gals of 80/140 transmission oil that it is now leaking from under the right brake housing and up thru the shifter as well. Did I put too much gear oil in the tractor? I let it drain all out but there could have been some still left in the bottom of the transmission. It called for 10.40 gal in the transmission so I estimated that there was still about a gal and a half left in there. I haven't personally checked the brakes but I assume the brakes are bad again due to the oil leaking into them. I put brand new seals in there and was thinking that I just put too much gear oil in and it was coming out the seals. He put the seals in as he saw them before. Any trick on how the put the seals back in? they were the standard international seals that we sized up and ordered from the case dealership. What do you think I should do? redrain the transmission and clean it up again? REplace the seals again? How much transmission oil do I really need in there if I only plan on riding the tractor in prades/shows and up the street? Maybe just half full so I wouldn't have to worry about it even coming close to leaking out the seals? I really need help because I am in the national guard and want to take it to my first show this weekend at my national guard unit and have it pull a hay wagon for the kids.
Please give me some ideas and sorry this is so long. Thank you very much.
Joel Shelton
C. Amick
10-20-2003 09:41:11
 Re: Seals and Case SC brakes----Help! in reply to Joel Shelton, 10-18-2003 17:43:38
Did you clean out the oil drain hole? There is an oil drain hole in the bottom of the big metal disc that the brake assembly bolts up against. It allows the excess oil to come out before it gets to the brakes. Run a wire up in there and see if it's plugged up.
Baggsy-Wy
10-18-2003 18:25:45
I replaced those same seals in the SI and found that it took a little 'road time' before they sealed up good. Take her to the parade but be careful. Not sure on the SC, but on the SI you fill the rear-end from a square head plug in the back, and it was impossible to overfill without aiming the tractor downhill. Where did you fill the tractor at? If above that level, I would drain it off to that level and call it good. That stuff's too expensive to not use...
Joe Shelton
10-18-2003 18:33:37
 Re: Re: Seals and Case SC brakes----Help! in reply to Baggsy-Wy, 10-18-2003 18:25:45
Bagsy,
There were two plugs on the left side rear of the seat. A big one and a little one. My diagram book said that it was the transmission fill and I put it in there. Again, I understand a little leakage but my father tells me is it drip drip drip. Still searching for ideas.
Joel
OL Chief
10-19-2003 03:54:18
 Re: Re: Re: Seals and Case SC brakes----Help! in reply to Joe Shelton, 10-18-2003 18:33:37
Looks to me like four possibilities to cause your problem. Seal size incorrect(measure shaft size and check w/a bearing supply house to confirm the proper inside fit to your shaft). 2- Seal installed backward( certainly, almost unlikely), any way ,check it out. 3- Seal seating area on the shaft may be grooved allowing the lip of seal to much clearance.Cure is (install a speedy sleeve from a bearing supply) or seat the seal position a bit out of the original location either in or out if space allows. 4- The seal may have been damaged sliding over the splined shaft.Case has an installation tool for this which is a very thin steel sleeve to slide over the spline.Then the seal is lubricated and slid over sleeve to it's cavity and driven home. You can accomplish a safe installation by simply wrapping a couple of turns of .002" or .003" brass shim stock over the spline then slide the new seal on over the shim w/out damage. By the way; my memory does not serve me about this but is there a gasket or o-ring between the cheek plate and the gear case.If so I would replace what ever is there while it is open. Good Luck
Baggsy-Wy
10-18-2003 20:58:18
I had to go pull out my S series Service Manual, and I see what you've got now. It shows the larger square head plug on the top as the transmission filler. Then down below that (and almost hidden in the picture), is the transmission level plug. I'm guessing this is what you filled it up to. The photo also shows the motor lift filler and level plug, but I'm guessing you don't have the motor lift. If you filled to the lower plug, it sure can't be up to the gear shift's level, can it?
On the dripping brake, I would pull the cover off again, pull the plates and peer in there with a flashlight. Make sure you didn't bump the seal out of kilter and make sure it is tight around the shaft. If it's dripping like that, something is wrong in there. You may need to see inside the other one to ensure what it should look like. At least now you have one to compare against...
