VAC 14: Good buy or should I run away?
johnG
10-18-2003 00:09:48
I'm looking for a small tractor for my acreage and came across a VAC 14 with a tricycle front end (1954?) that is for sale locally. It had been abandond with a siezed engine and was picked up by a mechanic six years ago. He rebuilt the engine (with new lower bearings) and it has only been used in the tractor pull at the local fair once a year since then. It started right-up after sitting for two weeks in pretty constant rain and runs nicely.
It comes with a parts tractor which has rear rims and a complete rear end as well as a wide front end. Not much more I'm told, but I haven't seen it.
BUT!!! The hydraulic pump was stripped off 7+ years ago and the lines are just dangling. AND the PTO shaft/splines have been stripped (although the clutch works).
Are hyd.pumps hard to come by or are old ones hard to rebuild? Is the PTO shaft hard to replace? Is it possible to swap to a wide front-end (I have a sloped property) or is this utter sacrilege? Without offending the enthusiasts, I'm not interested in doing a full restoration. I just need a working tractor, and I'm not in a position to take on too big a project or buy a fully restored machine.
SO THE QUESTION IS: If a VAC 14 were otherwise solid and running well with good back tires, would you consider it worth 900$CND ($650US) if you would have to make the repairs listed and are the repairs manageable?
JR
10-23-2003 17:34:11
 Re: VAC 14: Good buy or should I run away? in reply to johnG, 10-18-2003 00:09:48
I NEED SOME PARTS FOR VAC-14 IF YOU GET IT LET ME KNOW IF YOU HAVE ANY PARTS FOR SALE.
jdemaris
10-19-2003 07:50:07
Where I live (central New York State), a complete VAC can often be bought for not much more. I bought a wide-front end VAC tractor with Eagle hitch and PTO for $700 a few months ago. It's in original condition with barely any paint on it, but runs great. I had a chance to buy a VA at the same time for $400, but it did not have the Eagle hitch and also did not have the Case engine (had a Continental instead). I also bought two DCs, both run great and both have Eagle hitches, live hydraulics and live PTOs. One has a narrow front and one has a wide front. Paid $900 for the running pair along with an older parts DC (an all fuel tractor with no hitch). I guess it all depends where you live and how many tractors are still around. Farming is just in the process of dying here. Old tractors all over the place, but getting scarcer and prices are going up. An awful lot of them are going straight to the scrap yard, which is a shame. But, since China is paying close to $200 a ton for scrap metal, many people cleaning up old farms are scrapping the old stuff out. Last week, I came across a good running DC, an Allis Chalmers HD-3 dozer with 6 way blade, and a Cat D-4 crawler with a good running pony motor, all at the scrap yard, and all got destroyed. I begged the guy who runs the place to sell them to me (for the price of scrap), but he wouldn't do it. Told me it's not legal for him to resell to the public. So, the stuff will be in shipped to China, and back as God knows what soon.
Slowpoke
10-19-2003 01:15:56
You need a pump for the Eagle Hitch if the tractor has one. Can the parts tractor supply a pto shaft and pump?
Changing to a wide front end is OK unless the build sheet specifies a narrow front and you want to keep it exactly as it left the factory.
Lincoln
10-18-2003 17:32:00
Its well worth the asking price. Rebuilt hydraulic pumps are around $250(US) other parts are redily available. A friend of mine has one and it seems pretty high geared. Even in the lowest gear it goes to fast for me to mow with.
Mike
10-18-2003 16:20:48
The tractor is well worth that.Parts are easy to get.My 2 cents.
Bill N
10-18-2003 18:03:31
 Re: Re: VAC 14: Good buy or should I run away? in reply to Mike, 10-18-2003 16:20:48
Not a bad price, depends on how much tinkering you like to do or the time available. Sometimes it is just as good to get a complete one that you can hop on and go. My best advice = get exactly what you want the first time around. Bill N.
