DC Case with runaway governor...Cause?
George H
10-17-2003 19:14:30
My neighbor is looking to buy a DC CAse, it either doesn't respond to throttle, or rpm runs away...any idea what the problem is? Do you have to remove the cast flashing to correct governor problem?
Thanks
klyde
10-17-2003 21:15:08
 Re: DC Case with runaway governor...Cause? in reply to George H, 10-17-2003 19:14:30
Start at the carb- loose arm on throttle shaft is the first thing to check. Any worn link affects governor response. Can be removed with the mag drive but will have to be retimed,(no big deal) just mark it well and don't turn the crank!
