Case 600 rear hubs
Mike
10-17-2003 17:52:05
I have a 600 case diesel with 18.4-34 cast rear hubs, i have weld on hubs to fit the tapered axles but have to get old ones off first, made a puller from 1-1/2" steel, used heat, bent puller with 3/4" grade 8 bolts, have a new 10 ton porta-power ordered to help push from the inside, any other suggestions. I've seen a lot of stubborn hubs but these beat all!!!! Mike.
Joe (Wa)
10-18-2003 13:10:09
 Re: Case 600 rear hubs in reply to Mike, 10-17-2003 17:52:05
Hi Mike, I've only done a couple of these but a heavy puller strain and an engineer's alignment tool got the job done. Good luck, joe
Klyde
10-17-2003 21:21:29
Put your puller back on and tighten it just to were it starts to bend and then give it a healthy click with a 16lb. sledge. always worked for me.
R. Marg
10-17-2003 18:27:56
I there any way you can put some heat to them with out hurting other things if so they should brake loose if you can heat them up and pull /hammer while still hot
