Suggestions for Manuals, Case 49 VAC?
n2deep
10-16-2003 19:46:46
I believe that my tractor is a 49 Case VAC, the number on the plate is AC 5350691. We started it last week and now have air in the tires and are working on the Eagle hitch/hydraulics. I would appreciate any suggestions on manuals to buy for the tractor and the Eagle hitch.
Thanks
Art
DonH
10-17-2003 02:59:10
 Re: Suggestions for Manuals, Case 49 VAC? in reply to n2deep, 10-16-2003 19:46:46
Your local Case IH dealer can get you the correct manuals.
Joe (Wa)
10-16-2003 23:18:59
N2deep, For a '49 Vac, I would not buy a service manual dated earlier than 1950, later manuals will have updated info and correct mistakes & omissions in earlier manuals.
Case has a separate eagle hitch hyd system manual for dealers. It shows up on ebay occasionally.
If you need a lot of parts or are restoring a 1949 or later Vac, buy an E61 (1959) or later parts manual. It will have some of the updated part numbers that are the subject of repeat posts on this board.
Check the parts manual @ the link below. It is ragged & useless to a collector of antique manuals but, in my opinion, this is an example of the perfect parts manual for a user. The binder holes indicate commercial use, Case dealer or parts distributor. It obviously has had a lot of use and the seller warns that there is writing on the pages. Now what is you best guess as to what a parts person would write in a parts manual while they have a phone in one hand and trying to come up with the latest part number for a customer?
No you don�t have to pay $40 for it, there are probably 100�s around. This is the 3rd time around for this manual and I can�t believe no one has taken it for minimum bid. I must be missing something?????....Joe
curtis
10-16-2003 21:06:48
i used a t&c from tractor supply the guy's at this website have the same book's it's a simple tractor to work on you can take it apart and put it back together in like one day !
