Pulling with a case 312
Case Puller
10-16-2003 18:20:21
Hi, I have been pulling with my case 312 for a long time in the 4500 class. I was wondering if there was anything I could do with the motor to get better even if it is modified. Anything about pulling with a case 312 is helpful.
Thanks. Case Puller
ScottCT
10-20-2003 15:18:09
 Re: Pulling with a case 312 in reply to Case Puller, 10-16-2003 18:20:21
I don't know what to tell you, I pull a 311 (round nose) stock in 3500, 4000 and 4500 and have never had any power concerns, 3500 and 4000 I use third gear (lo range) and on 4500, I use 1'st gear (direct),and have always been very competitive in both stone boat and transfer sled pulling ( in stone boat, I go up thru 5500#.) I will be upsizing wheels next year to 36's, right now I'm on 14.9 28's. I am anticipating having to go down a gear in each class to remain at the same speed as before. Is 312 a tripl range? Any questions, feel free to respond
Case Puller
10-21-2003 16:35:34
 Re: Re: Pulling with a case 312 in reply to ScottCT, 10-20-2003 15:18:09
Yes my 312 case is a triple range and it is the same as yours but a high clearance tractor, and I pulled in the 4500 in 2nd Low at the first pull at our fair in wet condition and it had spun out but did good, But the second time I had pulled in 1st direct in a dry but sticky track and I had run out of motor. But that was my fault because if I had pulled in lower gear I wouldn't have run out of motor and I probaly done really good. But I did get 7th out of 12 tractors. And I haven't done anything to it. I was just wondering if anything to do to get ready for our next pull. Thanks for responding, if you have any answers or questions please write back.
KennethM
12-18-2005 04:01:49
 Re: Re: Re: Pulling with a case 312 in reply to Case Puller, 10-21-2003 16:35:34
I have just aquired a 312 and would like to restore. Would much appreciate any info/pics, etc.I could find. Please help if you can.
ScottCT
10-23-2003 09:28:17
Mine is stock, save for air cleaner and hotter coil. What size rubber is on a 312? This may affect my decision to up size. Thanks in advance
Case Puller
10-24-2003 16:17:42
 Re: Re: Re: Re: Pulling with a case 312 in reply to ScottCT, 10-23-2003 09:28:17
The tire size on my Case 312 is 12.4-36.
But if your put 36's on you tractor it might not be a bad idea. You would just have to drop a couple gears. I been thinking after I had pulled, And at the last pull after our fair the track was pretty hard, and pulled in 1st direct which was 3.0 mph. and it did place 7th, but it did run out of motor. And the next time I would pull at the same track conditions I would probaly pull in 2nd low which would be 2.7 mph. which it wouldn't run out of motor I would think. It all depends on the track.
Thanks for your your info. If you have anymore comments or questions I'll be watching.
John H-WI
10-17-2003 16:22:45
Don't want to throw water on anyones fire but we had a 300 and I will say it was one heck of a worker on the farm. Pulled 3 14's all over the hills plus a baler and wagon but it did not have the horses to compete in the pulling. This is strictly stock I'm speaking of. The 530's would outdo us all the time. The 300 only had 34 hp and the 350/530's had 42. Easier to boost up also. The only weak link in the 300 is the rear-end. They have the same setup as the VAC. We split ours on the disk one Spring.
C. Amick
10-17-2003 14:48:23
I'm not knocking your 312, because I have a 311, but the information I've seen says that the 311 and 312 are not very competitive. They suggested trying to find a Case 351 which must have a bigger engine.
