How to fix rear bearing in 870 case tractor
ZEE
10-16-2003 16:41:14
Just recently my seal on the right rear wheel started to leak oil (tr) when we opened up it looks like there is some play thus the bearing must be replaced. I am looking for info on this topic Thanks
Thad
10-18-2003 04:21:46
 Re: How to fix rear bearing in 870 case tractor in reply to ZEE, 10-16-2003 16:41:14
You might not need a new brg. You can tighten them up. They are a tappered brg in a cup. So you must pull off the pto housing to get to the bull gear. Then tighten the nut on it to take out the slack and you will probubly be fine. Thad
