Belt pulley brake pad revisited
Les...fortunate
10-16-2003 05:57:03
Thanks for the serial # of that thing, Klyde. I finally heard back from the dealer and he tells me that the part is no longer available. Guess I'll explore other avenues. Thanks to all who responded.
C. Amick
10-16-2003 07:22:30
 Re: Belt pulley brake pad revisited in reply to Les...fortunate, 10-16-2003 05:57:03
Do you need the whole assembly or just your's re-lined? I think I can find a used assembly for you, email me if interested.
Les
10-16-2003 08:05:40
 Re: Re: Belt pulley brake pad revisited in reply to C. Amick, 10-16-2003 07:22:30
Just to get it relined. I may take you up on it. I'm going to have to look at it a little closer. I've forgot where you're located. (?)
C. Amick
10-16-2003 08:46:03
 Re: Re: Re: Belt pulley brake pad revisited in reply to Les, 10-16-2003 08:05:40
I'm in West Virginia 25962. The local guy here would probably re-line it for around $10. I have a couple Case SC brake discs that I need to get him to re-line for me as well. I think he charges $25 each for them.
Don Rudolph
10-16-2003 10:34:45
 Re: Re: Re: Re: Belt pulley brake pad revisited in reply to C. Amick, 10-16-2003 08:46:03
Hey Les,
I just picked up two belt pulley brake pads from the local Case-IH dealer. They were on back order but I did get them and the rivets to go with them for about 12 bucks each. I could check w/ them and see if they can get some more if you like> Don
Dan in Ore
10-18-2003 04:22:54
 Re: Re: Re: Re: Re: Belt pulley brake pad revisite in reply to Don Rudolph, 10-16-2003 10:34:45
Don,
Would you e-mail me the part number for the brake pads and the rivets please? I have a 1930 CC that I put a piece of belting on. It works well, but doesn't last worth a darn.
Thanks in advance.
Dan
