Case 830 diesel
moline
10-15-2003 11:20:51
We have an 830 diesel with the serial number tag missing from the sheetmetal.Are the numbers stamped anywhere on the machine?The tractor is a comfort king if that helps.Any help would be appreciated.Thanks
INCase
10-17-2003 07:54:01
 Re: Case 830 diesel in reply to moline, 10-15-2003 11:20:51
Dale is correct. My 730 has SN on tag and on rear left mounting flange on motor, both match. If motor is original it should give you the info you need.
Dale In Tx
10-15-2003 17:20:04
The serial no should be stamped on left side rear flange next to bell housing,serial # and motor no. are the same. Dale In Tx.
Roger
10-15-2003 14:16:52
There isn't any other place on the tractors. The only way that I would know is if you have the engine serial # to have Rich look for the build card that way, but I would think that the build cards are only filed by tractor serial so searching by engine # would take him forever.
