case 811B
tbair
10-15-2003 07:17:27
I am a frequent visitor to the Oliver board owning
a 77 and an 88 diesel. I got a call from a gentleman the other day and he said he bought a
Case 800 gas from my grandfather over 25 years ago
and wondered if I would be interested in buying it
from him. My grandfather past away this last January and I have lived on the farm his father
bought for ten years so how could I refuse.
I got an owners manual with the tractor and while reading through it noticed references to type A and type C transmission fluid. I know dexron is a
safe replacement for type A but I have never heard
of type C, what is a good replacement? I will also
be needing a complete seat sometime in the future.
Any sources of replacement parts?
Thank you in advance for any help or suggestions,
I ame sure I will have plenty more questions.
toby
david
10-16-2003 08:23:34
 Re: case 811B in reply to tbair, 10-15-2003 07:17:27
You can still get Type A at most Dollar Stores
caseman-d
10-15-2003 20:59:44
I did some checking in my conoco product book and it lists a type c-3 wnich is a 20w/32 hydraulic oil. It's been a while since I have read my manual but I think it called for Type A in the pto and the converter and then the type C in the trany.. As most IH shops will tell you run hy-tran in everything. I disagree with that as I have tried an equivulent to hy-tran and am not satified with it in the converter and plan on switching it to use dextron if I get it running again. You can do a search in the archieves and most experts will tell you to use dextron. If you are having trouble shifting it into gear idle the tractor down. As far as parts, since I sell Case/Newholland parts I suggest giving your local dealer a try. Good luck with the tractor.
caseman-d
tbair
10-16-2003 05:30:45
 Re: Re: case 811B in reply to caseman-d, 10-15-2003 20:59:44
Thanks caseman, I called the owner last night and
he said he had put hy-tran in everything. I just started to get familiar with the tractor last night. At Idle is it normal to hear what I can
best describe as a whiring noise coming from the
front of the transmission area? Would the change to dexron make a difference?
Thank you.
caseman-d
10-16-2003 20:59:46
 Re: Re: Re: case 811B in reply to tbair, 10-16-2003 05:30:45
third party image
I don't recall a whirling noise in mine. You might try changing the convertor to dextron, if the transmission is shifting alright then I would leave it. Does your oil smell burnt, might also try cleaning the convertor filter. When idling what your convetor pressure and then step on the clutch to see if it drops fast, pressure should run in the green on the pressure gauge.
Rob Spray
01-03-2004 23:10:47
 Re: Re: Re: Re: case 811B in reply to caseman-d, 10-16-2003 20:59:46
my tractor has like a whirling/whining noise in it to but i changed all the fluid, cleaned filters, etc... and its still there so dont worry about it, i use mine every summer for hay season and absolutely love it.
tbair
10-17-2003 04:47:36
Nice picture caseman! Pressure runs just above the
green area on the guage and does drop when the clutch pedal is pressed, transmission shifts just
fine. previous owner said he changed all filters
and fluids, I'll check things out.
chad
10-15-2003 17:11:48
Don Livingston could set you up with just about anything you would [email protected] or 507-433-0073
tbair
10-15-2003 18:25:56
 Re: Re: case 811B in reply to chad, 10-15-2003 17:11:48
Thank you chad.
