530CK - Bleeding the power steering
Mike Fallavolli
10-14-2003 22:03:13
I had to disconnect the manual pump on the power steering system on my 530CK to remove and fix the fuel tank. As all of the fluid was removed from the lines to the manual pump, I'm fairly certain that I somehow have to bleed the system in order for it to work properly.
Can anyone fill me in on the details for bleeding this part of the system?
Thanks as always.
-- Mike Fallavollita
George S. in the real NY
10-15-2003 06:38:31
 Re: 530CK - Bleeding the power steering in reply to Mike Fallavollita, 10-14-2003 22:03:13
This is easy. When you are ready to start the tractor, make sure there is fluid in the PS tank, start and run the tractor, turn steering wheel slowly each way, check fluid level and all will be ok. I had mine all apart, the cylinders were dry and that is all I did, works great.
