distibutors for SC
Bill N
10-14-2003 17:47:12
I have two SC's with magnetos and would like to replace them with distibutors. Where can I get what I am looking for? Thanks in advance! Bill
chad
10-15-2003 17:20:58
 Re: distibutors for SC in reply to Bill N, 10-14-2003 17:47:12
give Don L a [email protected] or 507-433-0073
Joe
10-15-2003 04:26:57
Druther have a good mag any day.
John Saeli
10-15-2003 05:45:00
 Re: Re: distibutors for SC in reply to Joe, 10-15-2003 04:26:57
Right ONN Bill!!
John Saeli
10-14-2003 18:11:46
Hey Bill; What's wrong with them mags?? Do they spark?
Larry
10-14-2003 17:49:19
I have a Delco distributor that came off a Farmall H that will fit a Case or Allis. It has thw 6 volt coil with it. E-mail me if you are interested.
Bill N
10-15-2003 18:02:35
 Re: Re: distibutors for SC in reply to Larry, 10-14-2003 17:49:19
One mag sparks, but you can set your watch for 20 seconds and it dies instantly. Can't get much field work done in that amount of time. The second mag I was going to touch up inside and put on the first tractor. Must have put the thing back together out of time. How do you correct that problem Bill
Mike Sheldon
10-16-2003 18:54:53
 Re: Re: Re: distibutors for SC in reply to Bill N, 10-15-2003 18:02:35
I would like to have your mags if you want to get rid of them. Would make my tractor all org.
To time the mag, align the single timing dot on the drive gear with the center of the two timing dots on the driven gear on the rotor, hope this helps
Bill N
10-17-2003 18:06:45
 Re: Re: Re: Re: distibutors for SC in reply to Mike Sheldon, 10-16-2003 18:54:53
Thanks mike, I will use your info. Will also contact you if I decide to get rid of the mags. How about a swap for your distributor????
Mike Sheldon
10-17-2003 18:18:00
 Re: Re: Re: Re: Re: distibutors for SC in reply to Bill N, 10-17-2003 18:06:45
I don't have a distributor, my coil was burnt out, and removed it and put an external coil on.
now my mag acts as a distributor only.
