Case 530 hydraulic pressure adjustment
Chuck
10-14-2003 11:51:53
I have a Case 530. I put a pressure guage on the hydraulic system by the loader controls. The pressure reads 1200 PSI and it is supposed to be about 2250. I was told the adjustment is also on the front of the loader control valve. I am not sure if it is the screw with the locknut on it or do I have to take a cover off to access the adjustment. Any help would be appreciated.
Steve Schmittgens
10-15-2003 12:23:17
 Re: Case 530 hydraulic pressure adjustment in reply to Chuck, 10-14-2003 11:51:53
Chuck,
On the front of the valve is a big acorn nut, take that off then use a screwdriver to adjust the pre-sure accordingly
Steve
Chuck
10-15-2003 13:08:31
 Re: Re: Case 530 hydraulic pressure adjustment in reply to Steve Schmittgens, 10-15-2003 12:23:17
Thank you very much Steve. I found the adjustment myself this morning but, you are exactly right. I cranked my pressure up from 1200 psi to 1900 psi. Thanks again!
