VC Tune Up Parts
Brad Wies
10-14-2003 08:22:01
Hi guys if any of you have the numbers I need for the tune up parts I would appreciate it! I need the numbers for the cap, rotor, points, and condensor, I need a coil (do I need a resistor or not? it is a 6 volt) and what kind of spark plug wires do I use? Thanks!
-Brad Wies
Jared Chaddock
10-14-2003 19:27:32
 Re: VC Tune Up Parts in reply to Brad Wies, 10-14-2003 08:22:01
My VC uses NAPA AL91 Dist. cap, AL38 condenser, and CS709 points. I couldnt find the rotor number. If you take the number off your distributor, they can look it up at your local NAPA store, and find the parts for you. With a 6v system, you shouldnt need a resistor, usually that is only necessary on 12v systems. For most of our tractors, I usually buy an inexpensive automotive plug wire set that has the ends that I am looking for, and modify the length to fit. If you are lucky, you can guess on an engine that will have wires that are pretty close. ( an old 250 6 cyl chevy set works pretty good on an Oliver 6cyl)
Brad Wies
10-14-2003 20:57:23
 Re: Re: VC Tune Up Parts in reply to Jared Chaddock, 10-14-2003 19:27:32
Hi Jared, thanks for the part numbers, I really apreciate it. I am going to my grandparents farm this weekend and want to pull some wagons with the VC, I will be sure to take some pictures if this happens!!
Thanks Again!!
-Brad Wies
