Found a Free LA
TMAC
05-17-1999 17:09:48
I think I can pick up a '49 Case LA for free. I don't care if its collectable or not; I just want one to fix up. It has good sheetmetal. It is missing the mag and starter and the manifold will have to be replaced. Are parts hard to find for this tractor?
John
05-17-1999 21:43:45
 Re: Found a Free LA in reply to TMAC, 05-17-1999 17:09:48
A mag should be easy to find. However you may want to consider repairing your old manifold as a good used one is quite rare. If you get it welded you will have to remachine the manifold faces flat, as they are prone to distortion. A lot of the old LA's run rough because they are usually sucking in air at the faces and screwing up the air/gas mixture.
