Totaled Tractor
Brandon Lakin
10-13-2003 18:24:35
My dad and I have a slight problem with our 630 Case. He was out mowing at about 11 a.m. this morning, and he fell through a soft spot over a field drain tile. Needless to say, the tractor has been totaled. It was covered by insurance, but it will need a lot of work to get it restored. I was wondering if anybody had parts or knew of some suppliers from where to get parts. Pretty much the whole front end was ruined. Miraculously, even though it fell in the tile and was submerged in about 3 feet of water, it started right up. It has had a engine overhaul, and a new rearend in the last 2 years, but now needs a new front end. If anybody could be of help, that would be greatly appreciated.
Tom in Mo.
10-14-2003 16:58:05
 Re: Totaled Tractor in reply to Brandon Lakin, 10-13-2003 18:24:35
A replacement front end and maybe a little sheet metal sounds like an easy fix to me. Check the archives for a few salvage yards or get a parts tractor and you are on your way.
Brandon Lakin
10-15-2003 19:04:53
 Re: Re: Totaled Tractor in reply to Tom in Mo., 10-14-2003 16:58:05
Thanks for the tip. The only problem is finding a salvage yard that still has decent looking parts and won't charge an arm and a leg for them.
cb
10-14-2003 06:47:23
Is tricycle or wide front end. I have a Tricycle front end Super C that had the front tires broken off and was welded back. It is common failure on old IHC Super C.
Sounds like you have a good tractor that needs a little front end work.
Brandon Lakin
10-15-2003 19:03:19
 Re: Re: Totaled Tractor in reply to cb, 10-14-2003 06:47:23
It is a tricycle front end.
chad
10-14-2003 05:34:32
im sure don l has what you [email protected] or 507-433-0073
PhilCase55
10-14-2003 05:24:32
Where are you located? Was it a gas or diesel tractor? I have a gas 630 that was a good tractor until August when it threw a rod. If you decide to part it out I might be interested in the engine. Or I may decide to part mine out I could have the front end you need.
Brandon Lakin
10-15-2003 19:02:03
 Re: Re: Totaled Tractor in reply to PhilCase55, 10-14-2003 05:24:32
We are located in Rensselaer, Indiana. Right between Indianapolis and Chicago off of I-65.
anomonous
10-13-2003 20:37:23
Are you sure it was a Case Tractor, I managed to run myself over with mine and it ran into the house crashing into the spare bedroom and winding up in a closet, hardly a scratch on the tractor, still waiting for the bill on the house.
Brandon Lakin
10-15-2003 19:00:20
 Re: Re: Totaled Tractor in reply to anomonous, 10-13-2003 20:37:23
Yes, it was a Case tractor. My dad wasn't near a house, but the tractor ended up with a little more than a scratch on it.
