PLEASE HELP, Injectors, pump, or ???
MGM
10-13-2003 03:02:40
Rebuilt A401 diesel in Case 930, New sleeves, pistons, rings, bearings , bushings, you name it, had all the heads redone. I have excessive fuel coming out of the front head both 1 and 2 cylinders, Front head has been replaced, There is white cool smoke and backfiring out of these 2 cylinders, Middle and back head are burning smooth as silk, Pump and Injectors were all redone prior to start up. Filters and lines were bled several times. Youd be a life saver if you could help me get this problem solved, Thanks to all help in advance.
Mike S.E. MN
kyhayman
10-13-2003 18:29:55
 Re: PLEASE HELP, Injectors, pump, or ??? in reply to MGM, 10-13-2003 03:02:40
I had broken rings on startup with a new OH. A couple of times machine shop had the wrong psitons (put a .030 piston in a .040 sleeve. Different shop didnt check close enough and the block had been bored .020 on 2 cylinders, .030 on 1, and none on the other. They took .020 off all of them and that made the .040 piston slap.
Steve Schmittgens
10-13-2003 09:00:33
MGM,
To eliminate the injectors as the culprits, swap them to the heads that are firing smoothly. If problem persists in the new spots you have the answer, if not then you've at least eliminated the injectors as the source of the problem.
Steve
MGM
10-13-2003 16:28:00
 Re: Re: PLEASE HELP, Injectors, pump, or ??? in reply to Steve Schmittgens, 10-13-2003 09:00:33
Swapped injectors , still problem on #1 head, ran tractor for about 15 minutes and it seems to come around, have not yet did a compression test but why with a new build would that happen , 99.5 % positive rings are on right. But hey, were all human and do make mistakes,
Thanks guys
Mike
MGM
10-13-2003 04:20:56
Power cells are installed in new head.
Thanks
Mike
RoyG
10-13-2003 04:06:48
First guess is that the power cells were not put in the replaced head
