source of my drawbar confusion
david
10-12-2003 20:05:21
this is a picture I found that makes me think I am missing lots of parts from the pictures in the previous post
Wheat Straw
10-13-2003 05:59:53
 Re: source of my drawbar confusion in reply to david, 10-12-2003 20:05:21
David,
Your comparing a case eagle hitch to a ford 3 pt. That wont work as the eagle has fixed draft links. It doesn't swing back and forth therefore you dont need the stableizers like you do on the standard 3 pt hitches. Your simplest "fix" is to get a swinging drawbar for that tractor that will be completly independant of the 3 pt. It has the hinge point up on the front of the housing . This would be a safer system to as it is designed for the balance etc of this paticular tractor. Probably be cheaper to as you are only dealing with the one piece drawbar. check and see that you have the hardware that attatches it in the front end of the draw bar or get it when you order the draw bar. Bet Don L could get you one at a reasonable price. You can do a search and find him He's refered to a lot here.
Good luck,
Wheat Straw
David
10-13-2003 08:33:18
 Re: Re: source of my drawbar confusion in reply to Wheat Straw, 10-13-2003 05:59:53
Thanks I believe there is a hinge point under the tractor. Yes I am concerned about things such as balance so I will call DonL-David
