Case 900 leaks deisel into crankcase
JR
10-12-2003 19:03:32
my 900 is leaking deisel into the crankcase when its parked.I have the throttle lever in shutoff position. Dont think its leaking when I use it. I drain oil each time when Im done using it. Does anybody know what the problem is?? It has the rotary pump.
John Saeli
10-13-2003 05:10:44
 Re: Case 900 leaks deisel into crankcase in reply to JR, 10-12-2003 19:03:32
Hey JR; Give Ed Axthelm in Ohio a call. He explained a very simple fix to this problem but I've forgot the details. His name & # is in "Old Abe's". Keep us posted.
Gary
10-26-2003 14:22:42
 Re: Re: Case 900 leaks deisel into crankcase in reply to John Saeli, 10-13-2003 05:10:44
Check the seals on the injection pump shaft
Don Rudolph
10-13-2003 01:45:53
Sounds like you have a bad seal in the injection pump that is letting diesel fuel mix into the oiling system. Good idea to drain the oil every time.
