What is the easiest way to get the boot on the gea
Nicholaus Sowde
10-12-2003 13:42:53
What is the easiest way to get the boot on the gear shifter on my Case Dc? Thanks
Max
10-12-2003 21:25:30
 Re: What is the easiest way to get the boot on the in reply to Nicholaus Sowder, 10-12-2003 13:42:53
It may sound corny but spray some rubbing alcohol over the knob and slide the boot over while the knob is still wet. It is some amazing stuff and there's no slick shifter when you're done like when you use the normal lube.
Baggsy-Wy
10-12-2003 19:26:20
Threaded on the '48 SI...I took it off with a strap wrench when I replaced the bearings in the bottom of the steering. Just went out and checked it again to make sure. Comes right off now, but it was stuck when I started on the steering. Give it a good dose of PB Blaster...
Elliott
10-12-2003 17:18:09
Thanks Joel for the Info. I have one to put on my 1947 S C and didn't know what I was going to do. Didn't want to cut it. Thanks
Joe Shelton
10-12-2003 16:48:10
I recently put one on my case sc. I could not get the knob off so I lubed up the boot with WD40 and put it on over the knob. It took a little stretching but went back into shape once I got it over the knob and now looks perfect.
Joel
RandyD
10-12-2003 16:31:34
I used a small strap wrench I got at Sears to take the shifter knob off my SC.
Hope this helps.
Randy
Baggsy-Wy
10-12-2003 14:11:11
You gotta get the gearshift knob off first...then boil the boot to make it a little more pliable, and slip it on. Or is there something else I'm missing?
Elliott
10-12-2003 17:24:11
 Re: Re: What is the easiest way to get the boot on in reply to Baggsy-Wy, 10-12-2003 14:11:11
The 1947 S C Cases are not threaded on. Thay are pressed on. I broke one last month
Nicholaus Sowder
10-12-2003 15:09:43
The gear shifter knob does not want to come off. Is it threaded on or just pressed on? Thanks
dctom
10-12-2003 15:22:48
 Re: Re: Re: What is the easiest way to get the boo in reply to Nicholaus Sowder, 10-12-2003 15:09:43
THREADED BE CAREFULL
