wiring help on convert 56 311 6 volt to 12 volt
joe
10-11-2003 16:36:07
would anyone happen to have a makeshift wiring diagram to convert a 6 volt to 12 volt 1956 case model 311? i already have the alternator modifications, solenoid switched and the coil switched, i just need a little help on where my wires go. i put a delco alt. on it with 2 wires and any help or pointers would be appreciated!(and i have it so it will crank but i am not getting fire from the coil?
Allan C
10-11-2003 21:02:48
 Re: wiring help on convert 56 311 6 volt to 12 vol in reply to joe, 10-11-2003 16:36:07
If you're not getting any spark take a test light and see if you have power to the plus side of the coil when the ign switch is on. When using an alternator you must have negative ground so the coil should be wired with the switch to the plus side and the points on the - ( ground) side.
If there's power there you should have spark,or you have a distributor issue ( points, condenser, bad connections, etc. You should also have a resistor in the line to the coil to drop the voltage to about 8 volts from 12 or you will burn points. There are articles on this site on conversions. Have fun!
