anti-freeze foaming on S
Tim W
10-11-2003 15:03:35
My S started foaming the antifreeze out the over-flow tube. It is not running hot, in fact I have to cover the hood to get it up to 150*.
I let it sit over night and checked the oil and there is no anti freeze in the oil.I removed the thermostat and no help. I drained the anti-freeze and replaced with just plain water and it does not go out the over-flow tube. Why would the anti-freeze foam out, (I mean a constant stream) the over-flo and not just plain water?
Allan C
10-12-2003 16:28:49
 Re: anti-freeze foaming on S in reply to Tim W, 10-11-2003 15:03:35
If the antifreeze is old, just putting in new may solve the problem. Flush the system out with water before putting new stuff in. Antifreeze has anti-foaming agants and they wear out, just as in oil! It's also a good idea not to mix brands.
Tim W
10-12-2003 05:04:16
Thanks fellas, will check out those ideas.
Gene Dotson
10-12-2003 03:02:20
The first thing I would try is to grease the pump. Most Case water pumps use a seal that is pressurized by grease. Try this first, at least nothing invested ... Gene
Baggsy-Wy
10-11-2003 20:26:08
My SI did the same thing, but I never did find a rebuild kit for the pump. Ended up getting a rebuilt from Don L. Fixed the problem and no more foam...
george md
10-11-2003 19:38:03
Tim,
Warm it up and when it is making foam, stop it ,remove
the fan belt. If the foam stops you need a water pump seal.
Many water pump seals will suck air in before they
leak water out .
george
