SC Case wheel mounting???
G. L. Perry
10-11-2003 01:49:54
I've got my rear wheels painted again finally. I have cast centers and outer steel. On each side, six wedges with a LONG lip that say Goodyear on them, and six wedges, with slight taper on end that touches wheel. I can't recall which way they were on the tractor. I'm thinkin' the ones with bigger lip go inside and flatter ones outside. Not sure if I just tighten up the inners first, then mount wheel, or if I need to slip it all on loose and tighten, adjust then for run-out or something. Owner's manual has little on wheel mounting in it. Only has a Transparent like picture of wheels in it, but long wedges are shown on inside on one, and outside on other?? Help me out here. I'm betting the wheels will be all scratched up before all is done. I realize there is the tabs welded on that go into the "DIP" cut-out for each wheel, so it don't turn on rim. Where's a book with info on wheel mounting??
dctom
10-11-2003 06:59:09
 Re: SC Case wheel mounting??? in reply to G. L. Perry, 10-11-2003 01:49:54
the lugs with long lip go on the inside, just make then finger tight than mount wheel and draw up tight. tire should run straight than dctom
