Seal kit for vac eagle hitch
Jerry
10-10-2003 18:44:00
I was to the case dealer to get a kit or parts for this tractor 1950 vac. They said no longer made . Would any one know were I could get this kit?
Thank You Jerry
Don Livingston
10-11-2003 06:16:50
 Re: Seal kit for vac eagle hitch in reply to Jerry, 10-10-2003 18:44:00
Do you need the old style with the cup or the later piston with O rings? What is the casting number of the piston? Don L.
Jerry
10-12-2003 05:51:07
 Re: Re: Seal kit for vac eagle hitch in reply to Don Livingston, 10-11-2003 06:16:50
I took the piston to a shop and he had a replacement. What I need are the seals and orings in the shaft and controls. I will take it apart and most likely be able to find those idems but if thier is a kit I would get it. Thank you for your help. Jerry
Sam#3
10-11-2003 11:29:10
This isn't Jerry but I have the same problem, assuming he's referring to the rockshaft cylinder.
Are the leather cups available anywhere? Could a leather craftsman make them? Would a modern equivlent(synthetic) be available?
Joe (Wa)
10-10-2003 21:56:29
What do you mean by seal kit? Joe
chad
10-10-2003 20:01:31
try don [email protected] or 507-433-0073
