Couple more DB 990 questions
Robert in NY
10-10-2003 18:31:12
Hello again. I just got done looking over the tractor and talking to the owners to find out exactly what is wrong with it. What I have learned is that the rear remotes work but the arms won't. They said when they brought the tractor out of retirement in 2001 they hooked it to a brush chopper and it handled the chopper fine for two passes then it would no longer lift it. So they unhooked it and have not been able to use the arms since. So I am assuming the pump is fine and my problem is in the control valve somewhere. There is a lot of play in the raise/lower lever almost as if it is not connected partway. Any thoughts as I think this should help narrow down the possibilities.
Also, second problem with this tractor is the power steering doesn't work. Checked the resivor and it is empty so I am thinking there is a leak somewhere but is there any special type of ps fluid for the David Browns?
Sorry for my lack of terminology but I only play around with tractors and am in no ways a mechanical wizard. I am helping my friends out because they need it and I have no doubts I can get this thing to work with the help of this board. Thanks again for all your past help and any future help. Take care.
jim
10-11-2003 05:56:37
 Re: Couple more DB 990 questions in reply to Robert in NY, 10-10-2003 18:31:12
Robert - Try www.davidbrowntractortips.com
You'll get all the information you could ever wish for there. Jim
