300 roundnose I think
Larry
10-10-2003 16:11:30
Hi all, I have a chance to by a 300 roundnose I think? because the sheetmetal is missing.Do you guys think that this is a good puller?
Joe (Wa)
10-11-2003 10:43:44
 Re: 300 roundnose I think in reply to Larry, 10-10-2003 16:11:30
A G148 engine in the 300 was rated @ 33-34 pto and 29-30 drawbar. You can tell the difference between round nose & B model by the shape of the bolster front. Joe
Larry
10-13-2003 13:24:47
 Re: Re: 300 roundnose I think in reply to Joe (Wa), 10-11-2003 10:43:44
Thanks Joe
John H-WI
10-10-2003 18:27:16
What do you intend to do with after you gewt it? If its stock there isn't enough horses aboard. We used to pull our 300 at 5000 and it would die before it would spin out. Its only got 34 hp as it comes from the factory. The 530 and the 350 with 42+ would outdo us every time. This mind you was when farm tractors were required tobe stock. Then they changed the rules
and we quit pulling.
Larry
10-10-2003 20:08:02
 Re: Re: 300 roundnose I think in reply to John H-WI, 10-10-2003 18:27:16
Hi John,we just bought a hobby farm and a 1950 8n and are growing spuds. The 8n is too small to run the 5' rotavator and geared too high for the pulls so I considered this 300 case.But if you say it's only 34 hp then were no further ahead,thanks for the advice
John H-WI
10-11-2003 08:49:22
 Re: Re: Re: 300 roundnose I think in reply to Larry, 10-10-2003 20:08:02
For farming use they are a neat tractor. We pulled 3 14's in the hills with ours all the time, fluid and weights, plus the baler and wagon on behind. Its much more than an 8N, spent many hours on one of those also. Its just not a good pulling tractor as it stands.
Larry
10-13-2003 13:30:23
 Re: Re: Re: Re: 300 roundnose I think in reply to John H-WI, 10-11-2003 08:49:22
That's good advice John, I guess there's not much gain over the 8n so I think that I'll pass on this purchase, but I did like the high-low range as opposed to the 8n 4spd.
