David Brown tractor
Jim
05-17-1999 08:23:39
I'm looking for info on a 1972 David Brown I found in a grove in California. It's a diesel, don't know the model. Engine and trany oil have been drained and sat for about 6 years. Question is, are parts available and who carries the parts. I don't think the engine is stuck but the trany could be locked up.
Elmer
05-23-1999 06:25:17
 Re: David Brown tractor in reply to Jim, 05-17-1999 08:23:39
The only time i've come across a trany locked up is when the shifter fork pocket for the lever was wore so bad it slipped out and left the trany in gear. Tractor would move. The lockout detent would never allow two gears engaged at the same time. Although anything is possible. Actually i just remembered the very first trany i had apart, i thought the layshaft(clustershaft)had to have a bearing preload not end play. When i got it back together, the tractor didn't even make it out the door. Killed the engine dead. Had to skid it back in. Found out the layshaft needed .008 endplay, worked fine then. What model is it.
John
05-17-1999 21:46:22
Parts for that year should be available thru your Case dealer. 'Course they'll need the S/n & M/n.
