Seat spring for SC
gerald
10-10-2003 14:27:23
Anyone know where I could find the big compression-type spring that supports the seat on a '49 SC? I prefer a new spring, as used ones may be as brittle as the one I have(broken). Case dealer says they don't make them anymore. Any other resource out there?
Mike Schwartz
10-12-2003 21:41:48
 Re: Seat spring for SC in reply to gerald, 10-10-2003 14:27:23
If you have a shop in the area that makes truck springs or shanks for fertalizer applicators they could make a new spring for you fairly easy if you have the pattern. Have had this done for farmall seat springs in the past. Don't know where you are located but I used Pohl Springs in Spokane WA. Good luck, Mike.
chad
10-10-2003 20:05:58
try don l he may have a [email protected] or 507-433-0073
C. Amick
10-10-2003 14:32:53
You might check McMaster-Carr's web site to see if they have any springs that big.
gerald
10-10-2003 19:05:01
 Re: Re: Seat spring for SC in reply to C. Amick, 10-10-2003 14:32:53
Thanks for the tip and did check, but looks like they don't have the exact size. There is a number to call. Will check at local dealers first to see if can find a comparable spring. There's a small spring inside of a large spring on this--the inside spring is ok. Always a new challenge, and that's what makes restoration so interesting!
