steering arm
dctom42
10-10-2003 10:18:42
HEY CASE MEN; HAVE ANY OF YOU FOUND A GOOD WAY TO BUILD UP THE STEERING ARM ON SHORT STICK TRACTORS SO IT DONT DROOP, ?? ANYONE EVER TRY PUTTING A TIE ROD END IN PLACE OF THE BALL? HAVE TWO OF THEM THAT LOOK LIKE $HIT DROOPING SO BAD, ANY INFO WOULD BE GREATLY APPRECIATED DCTOM
DON L
10-10-2003 11:17:06
 Re: steering arm in reply to dctom42, 10-10-2003 10:18:42
I know what you mean. I find the the ball gets worn, not the round part, but the lower part of the shaft. the edge of the drag link rubs itself at that point. I have seen some 1/2 way thru the shaft. I have welded them shut and ground them back, higher than orginal to compensate the the wear in the draglink, or weld them both. Hope this helps your droupy link.
Don L.
dctom
10-10-2003 13:21:13
 Re: Re: steering arm in reply to DON L, 10-10-2003 11:17:06
thanks don i will do thatl i see the ball shaft is worn also, want to see what david dose to attach tie rod than start welding, dctom
david
10-10-2003 11:04:11
I've had to change things in the past from a ball to a tie rod. just have to ream the taper into the arm. See the link then look up ball joint reamer in the tools area
dctom42
10-10-2003 12:27:51
 Re: Re: steering arm in reply to david, 10-10-2003 11:04:11
David; can you explain how you use a tie rod end, drilling the pitman and taper no prob how do you attach big end to drag link? dctom
david
10-10-2003 14:35:03
 Re: Re: Re: steering arm in reply to dctom42, 10-10-2003 12:27:51
another way would be to take the pitman arm to a prototype machine shop drill the hole bigger, have a hardened bushing made and welded in place.
david
10-10-2003 14:32:45
You would have to get the matching adjusting sleeve then measure have the drag link cut and thread it, most decent machine shops could thread it (even reverse thread,acme thread ect.), and not automotive machine shops but a prototype machinge shop someone with lathes, mills ect.(I have a friend here in AZ that does my stuff). Small machine shops are hurting and you could have something like that done for $30. it blows my mind the stuff he can make for me cheap (I pay full shop price since it is his lively hood)
